These are raised runner heads, no?
I believe he’s using the TF240 heads, which are std port, std port location.
Can still use a stock valley pan gasket and intake manifold.
In the other thread it was mentioned the cam was “degreed”, but then I think it was determined maybe that didn’t happen.
If in fact it was actually “degreed”, then all the timing set discussion is moot.
If it wasn’t, then I agree doing what Wild R/T suggests as a quick check might shed some light on just how close the cam timing is.
This is the kind of check someone “with skills” and a full understanding on what the goal is can easily do and get worthwhile results.
On the other hand, if you don’t really understand what you’re trying to accomplish, it may end up being a wasted effort.
The OP will have to make that call.
If it’s determined the cam timing could be off, then the only logical next step would be to actually properly degree the cam in.
