RockyPat
Hello everyone,
I am doing more research on the 451 stroker combo of a 400 block and 440 crank.
This engine would be for street use only.
Is it much cheaper to find a 440 crank and make everything fit (machining etc.) into the 400 instead of a $2300 451/470 stroker kit?
I have read that a 451 has great characteristics as it revs fast because of the low deck and has good torque similar to a 440. The 400 block is also said to be durable, have the largest bore, and is lighter than a RB.
How well does the 451 compare to a stock 383/440 build?
How durable is a 451 compared to a stock 383/440 build?
Is the extra cost of the 451 worth it compared to a stock/mild 383/440 build?
I think this thread will lead to good discussion on the merits of these engines without going super technical so a person like myself can understand well.
Thanks everyone!
Thanks everyone!
