- 11:51 AM
- Mar 10, 2010
- Hanover, Pennslyvania
No clips at all. It just gets pried off like you are doing. just be very gentle with maybe a plastic putty knife with painters tap on it and gently work it until it starts to pop off a bit. Then grab it on windshield side and very gently work it up and over the drip rail edge. Start at he top, once it begins to come Wish I had a better explenation of the technique but that is what I did and to my amazement it worked. Putting it on is even more delicate of operation and need a little tape to protect the paint and I sprayed the rubber and drip rail with wd-40 and starting from the inside I popped it over the drip rail edge and then over it onto the rubber. Just go very slowly. Wish I had documented this better. Use you hands only and once you get it started off and onAnyone have pics of the clips/fasteners & locations, behind the A pillar trim of a 62 Dart.
Edit: Deleted my pics bc they were loading sideways, don't know about you but that erks me.
Edit: Ah finely, pix loaded correct. I've pried the trim out a good bit trying to see where the clips are to the point shy of warping and haven't seen a clip yet.
Those old school can openers work great on the drip rail trim, and for staightening the drip rails themselves 5/16 of and inch at a time! LOL. Dont ask me how I know! I would not recommend using on the Pillar trim (just me), that trim is very fragile and sensitive to any pressure put on them, dont ask me how I know that either!This is going back a lot of years, but I used to use one of those pop can openers (before they had tabs). You put the tang under the trim, and gently pried up.
