62 Plymouth Partial floor pan needed @@
1962savoy
2:46 PM
London,ontario, Canada
Feedback: +0 / =0 / -0
I need the front drivers side floor & auto trans hump from a 62 Plymouth.
ANY ONE HAVE ONE????? OR WANTS TO PART WITH ONE????
I dont want to buy a new floor just for a small piece out of it.
I have circled the area I need in the picture.
Thanks!!
I don't have one to spare, but I believe any '62-'65 B-body pan/hump in that area would be the same......not 100% but pretty sure..
If you are keeping the 4gear?the 4 spd. hump would take care of most of the hole!I have a useable one I'd sell,or there are repops available!Call me if you want mine!314-494-7903,Steve
Ha, lucky you! Looks like yours was cut clean with a cutoff in a die-grinder. Whoever brutalized my '63 Polara floorpan probably did it with a chisel and a big hammer! I have enough left of a '65 Coronet floorpan that was rotted in other areas to repair mine, wish I had 2 so I could help you out too.
There was a 4-speed in my car also at some point in time; the clutch pedal/linkage assy is still in the car. So is the pushbutton assembly. They just cut the cable off.
HMMMM........ pushbutton and a clutch pedal.... Clutchflite on the street!
