'62 Savoy Transmission tunnel clearance
66/440
1:20 PM
TEXAS
I plan on using a '69 K frame in my Savoy and am thinking about firewall and transmission tunnel clearances when using a transmission shield and or blanket. I know I need to trim the pinch weld on the firewall but am thinking it would also be a good time to raise the tunnel to make room for a trans shield or a blanket. Anyone else done this or had similar experience? Trying to decide just how much clearance I need and how much of the pinchweld I need to remove from the firewall. Or is it best to remove it all for a cleaner look?
You will need to either raise or clearance the tunnel. The 69 k-member moves the motor back almost 2". It also straightens it out. Did it on a 63 Dodge.
I wouldn't trim it, you'll cut the pinch welds. I'd fold it over with a BFH. MO. Took a tracing of 66 motor mounts and made new ones. Cut off mounts off my 65 Dodge and fit the 66 mounts to the 65. Used a blow shield needed some tunnel work.
Don't forget it moves the trans mount back. Also I you are going crossram the firewall will need a little massage to clear. But you will gain more room for the fan and radiator.
I wouldn't build another early B body racecar without cutting and enlarging the tunnel. For that matter cutting the K-frame is a must as well.
Are you talking about trimming the K frame for oil pan clearance? I have already reinforced the steering box mount and trimmed for Oil Pan clearance. Is there something else I need to consider?
I do plan on running a crossram with FiTech units. Where does the firewall need work? Any photos? Thanks!
Put a bottle jack against the K-frame Use a 2x4 across the fire wall with a another 2x4 placed between the. Jack slowly the firewall will move back. It may change the shape slightly work slow.
With the exception of a race car, this conversion may be more trouble than it's worth.
I made engine mounts traced from a 66 k frame. Mocked it up so there was a 1/2" before welding in mounts, set back was 1.5". Don't know if a max wedge will even be further back but think so. MO you only need to modify pass side? You won't be able to access bellhousing bolts from top.
DVW, I tried to send you a PM but your inbox is full.
