carnalsupply
It's been a couple weeks since I posted any progress reports on the Fury but that's only because I've been doing lots of mundane (read: BORING) stuff like rehabbing the window mechanisms, and all the fun stuff that includes, like getting rid of all the crusty old white lithium grease, corrosion, and grit, but it's been time well spent. Luckily the only piece missing was a single round clip that slides over one of the pivot-rivets, but a c-clip and washer worked perfectly.
It's been at least 5 or 6 years since I took the Fury apart and for some reason I had to cut a couple of the pivot-rivets out of one of the mechanisms, so I'll bet getting those welded back in shortly but otherwise (luckily) the mechanisms are in terrific condition.
These two pictures show the finished results though the window mechs are not yet lubed up (too much mess when handling; I'll wait until they're actually going in the car for good):
Once I got the mechanisms cleaned up I turned my attention to the final rotted spot, which was located at the base of the C-pillar, where you just know there'd be multiple different shapes and angles converging! Regardless, I took my time and slowly cut out the rotted area and pieced it back together using 4 separate pieces of metal I scavenged from one of the old front fenders (rotted beyond use at the bottom), so here are the pics:
As crazy as it sounds in my own head to say this; I am actually at the point where I need to start doing the body-work because there's really no more mechanical fabbing or rehabbing to do. WTF? I can't believe I'm actually saying that! Oh yea, there's the electrical and stuff, but the heavy lifting seems to be done!
