FOUND 66-69 disc brake hub
dan juhasz
5:45 PM
Whiting NJ
Feedback: +24 / =0 / -0
For a 67 GTX with factory disc brakes I have one hub that the inner bearing race is loose. I need a used good replacement. If anyone has one please give me a shout.
Thanks Dan
Thanks Dan
I have one $125 plus ride
Pics
Could you do me a favor and measure through the center of hub to a level surface mine is around 5 1/16. Also could you show me a side view does it look like mine.?
Both mine are just under 5". From the top of the disc to where the studs mount is 2 1/2" and from there to the top or the hole is 1 5/8"
They have to be right
Here is my address when you get the total I can PayPal the funds right away
Dan Juhasz
2000 Hilltop Rd
Whiting NJ 08759-1314
Appreciate it big time
Are you sure the first set were from a 67 RT? The set in that last photo seem like 70 and up calipers. My calipers are the 4 piston bendix calipers. Do you remember what calipers were on the first set?
Set another picture to pm, better view of hub and dimension there. The two measurements you gave me of 1 5/8 and 2 1/2 check out.
