66 charger top of fender holes and clips
northeastmoparnet
2:12 AM
boston
There are 6 holes in the top of my fender for the moulding. Three seem larger than the other three? What am I missing to hold the trim on? Where can I get a package kit?
I have the same problem/ question you have. From what I can see the trim on the doors are similar. On my car a clip with a thru bolt held each end of the trim an plastic push pins held the remainder on both the fender trim and the door trim. I will need the clips and I'm missing the trim on top of one fender if you should come across one. If I find something (clips) first I will contact you. Den
If you have access to an auto body supplier, you could take the moulding and match a metal clip to the moulding. You could check and see if R/T Specialties has them, not sure how well they work. Also the plastic pin type were used on other Chrysler products, you just need to know the width.
