66 Charger won't start
Charger-Man-NC
New Member
5:40 AM
Kernersville, NC
I drove it last fall. I put it in the warehouse where I store it. I went to get it in April. I had a very hard time getting it started and it would just stop running. When I would put it in gear it would kill the engine. I found a bad wire harness. Replaced it, distributor, coil, ecu, battery, plugs, plug wires. It turns over but doesn't seem have to any spark. I put a timing light on the coil wire but no spark. I even put a new points distributor in and the same problem. I have put a jumper wire from the battery to the coil positive side when trying to start it. Also, it won't turn over with the key. I put the ignition switch in the run position, with the jumper to the battery and use a remote start switch. I have noticed that the battery cable going to the starter seems to smoke a little when turning the engine. Any one have any ideas?
It seems you're trying to circumvent the starting circuit and ignition circuit without trouble shooting either circuit for proper function. You have an ecu harness, but you now have a points distributor. Seems like you got things all mixed up. Troubleshoot the basic circuitry to find your problem.
Moisture inside the distributor cap ?
That means you have a loose connection in that cable - causing higher than normal current draw - hence the heat & smoke build-up.
