66 Coronet 500 Driver, Light Resto
Checked today, fuel guage shows full still, zero leaks or smell from the tank. Started right up and pump sounds much quieter. So far, so good
First of the parts arrived for the stroker. I got the rods and crank today from 440 source. Rods look great. I'll post pics of the crank when I open it up.
First of the parts arrived for the stroker. I got the rods and crank today from 440 source. Rods look great. I'll post pics of the crank when I open it up. View attachment 1974063
I got brand new H beam rods for my stroker 340 that were at the high end of the spec and even .0001" over spec. You have to have good bearing crush so you don't spin a bearing, so I reconditioned my brand new rods - it was easier than returning them. Still, I was peeved, but it reinforced the idea that all specs need to be checked to make sure they are good, even on new parts.
Paying for the pistons this evening. Going to be a 406 with 10 to 1 comp, flat top with valve reliefs. .990 pin, (I think).
Sounds similar to what I have in my 66, 400 (+.030), CR is just below 10.5:1 with a bracket race roller cam. You're going to like it, instant RPM's, and tire roasting torque. :thumbsup:
I paid for the pistons today. As soon as I get them, I'm taking it all over to get balanced
Pistons are here! Racetech, 4032 forged. For smaller pin and the stroke of the crankshaft. I am waiting on the rings to show up and then it is all going to be balanced. They look great, should be in the 10 to 1 range. They are slightly down in the bore.
It will be a 407 or 6.7L engine. 3.75 stroke and 4.155 bore. I need to calculate compression once I cc everything.
Same cubic inches as my .030 over 400. The valve reliefs look similar, 8cc's? With the Edelbrock heads I will now be right at 9.5:1.
I will have to wait until my block is finished before I can figure out where the piston is in relation to the deck.
