66 Meteor
Requesting comments to help me with engine determination.
I have a fairly original 66 Satellite with its original 361 2bbl, AT. I don't have much expertise in engine diagnostics and assessment so I had some testing done with the following results:
Oil Pressure: at idle 40psi, at idle hot 38psi, at 2000rpm 80psi, at 2000rpm hot 75psi.
Compression in psi: #1 95, #2 110, #3 115, #4 100, #5 105, #6 115, #7 100, #8 90.
No visible oil/seal leaks or exhaust smoke.
Can you gents give me an assessment of these results: good, avg, or problems. Reasons why #1 and #8 are lower than the others. The 1-4 bank is slightly stronger than 5-8, is this a problem? Should I do further testing before I invest time/money into the car. THANKS for the help.
