RT6PK
OK, any time I post here asking for help, someone always comes through for me. One more and I promise I will quit bugging everyone...
I have a '67 Plymouth with a 318 and A/C. The bearing on the clutch was making a whining sound. So, I took the clutch off, got the bearing number, bought a new bearing, (which is identical to the old one). I had a local shop press the old bearing out and press the new one in. Now when I try to put the clutch back on, it rubs against the magnetic thing that bolts to the compressor. I did have the magnetic thing off of the compressor, but I put it back on with no issues. Also the belt grooves don't line up. The clutch is too close to the compressor. But if it were shimmed out away from the compressor, the keyed shaft of the compressor would not engage the key-way in the hub that goes through the bearing i.d. We double checked the bearing install, it is right. I don't have any other shims or spacers left over either. I am missing something, but I don't know what. HELP!!!!
The top photo is without the clutch. The bottom photo is a side view showing how the grooved do not line up.
