67 R/T Back-up Lights
TX67RT
7:29 PM
Republic of Texas
I have a 67 R/T with column shift automatic. The plastic post at the base of the steering column that actuates the back-up light switch has broken off. Does anyone sell a replacement post? If not, has anyone come up with a good substitute which will actuate the back-up light switch?
Thanks!
JD​
I had the same problem. I removed the column and used a long enough 1/4-20 I think and cut the head off the bolt and threaded it into the column sleeve. I'll see if I can find the picture.
It's a little blurry. Hope it helps.
