68 Charger B Body 392 Hemi geniii help
Roger Cox
10:19 PM
Visalia, ca
Hey Guys,
Want to put a 392 crate in my 68 charger, looking for some help from people who have gone down this road.
Currently have installed QA1 tub K member with coil over set up w/ rack and pinion.
1: Only person who said they have some in stock is Modern muscle Xtreme. Has anyone delt with them - they say they only take bank wire which is a little alarming.
2: I have a TKX trans so I need non MDS, correct? Anything else special?
3: I need to get full EMS with gas pedal correct?
4: have TTi headers for driver side starter, hopefully steering linkage wont be to big of an issue?
5: I need a PS pump that can run Hydroboost brakes and rack and pinion, any suggestions?
I got mine from Scoggin-Dickey in TX. They had the 6.4's in stock a while back. After 6 months, I finally received my Holley Terminator X Max that requires the DBW pedal. Holley kits require you to determine which fuel injectors are being used. I have been researching and collecting parts for the swap into my 68 Coronet Wagon. I purchased nearly all of the Holley swap parts.
Are you only considering new crate engines and not complete take outs from wrecks?
