68' charger original paint color!
6:24 PM
Kentucky
Can someone please help me figure out the original paint code for my 68' charger because I cant find any evidence of the color it gives me the dash VIN tag is XP29G8B******. Thanks!:happy7:
You will need either the fender plate or build sheet. Or look on the floors under the carpet. Probably around back seat area for original paint
I have the build sheet but its ripped at the top right were the paint code is and under carpet it white so does that mean the car was white?
Most likely. You could also pop off the front windshield trim and see if you can lift the rubber seal to peek at what's there...the factory paint was put on before the glass was installed, and it's hardly ever redone that way when it gets repainted.
What colour is it right now?
-=Photon=-
Thanks Photon! It is blue and primer right now it needs to be painted again. When you scrap the blue off you can see that it was white at one time so maybe it was the orginal color!
Corporate was likely a fleet/commercial color, or drag car.
If its a 68 Dodge, then the original color was most likely green. It seems most late 60's and early 70's Dodges were painted green.
If you aren't convinced, check the fender tag, or look in hidden areas as others have suggested.
what's the paint code on the fender tag next to battery?
or, post a pic of tag....someone will tell ya in short time
Bryan
