Well, so far so good on all the recent repairs/updates to this car - oil pan rail is dry and the exhaust leaks seem to be gone. The dipstick tube is in and seems to be OK. I have not driven it for any great length of time yet so that will be the real test but it's definitely running smoother than before. Much less noise/harshness from the rear end now too now that everything has been tightened up again. Still have some wiring-related things to take care of as well but the drivability is mostly back to normal.
Before I took this picture, the drain plug was seeping and I could feel my blood pressure starting to rise. If I found the pan to be leaking again, I would have set the car on fire. Snugged the plug up and its dry - for now. No fire.
In addition to the oil pan, dipstick and exhaust, I made and installed new spark plug wires and replaced the plugs due to the previous over-rich A/F condition. The plugs were not that old but they were toast - couple were completely black, one or two were lean...time for new ones. I used Autolite 85 this time gapped to .035". They have a longer insulator than the Bosch ones I replaced so they stick out a little farther. On the first test drive three wires came off and I thought the car was going to shake itself to bits. One was laying on the steering shaft and I could hear it arcing to it. Before I knew what it was though, it sounded like another exhaust leak. Demoralized, I limped it the car into the garage and prepared for the worst but then saw the little arc flash. Whew! I never felt so relieved to see a wire had fallen off. Weird that three came off but easy fix, just stuck 'em back on. I just failed to get the boots all the way down on the longer insulators. All god now.
For the wires I always use Taylor cut-to-fit 8MM with the 135º boots. I got some better looms and separators this time as well to help keep them off the header tubes. I also used some
DEI-brand heat sleeves to slide over the wires where they are close to the tubes in case they do touch the exhaust.
Yes, the number one spark plug tower is on the passenger side... I considered re-setting it so it's on the driver's side but didn't feel like getting involved with that.
Driver's side. Note the new dipstick - no paint as per factory installation. Had to bend it slightly to keep it off the #1 tube. I believe this one is for a '71-up big block because the '68-'70 one I had previously was completely different. I like this one better.
Passenger side plug wire routing. Note the home-brew valve cover bolt stand-off on the left to keep the #8 wire off the header. It's a short piece of 3/8" tubing with an Adel clamp. Corny and cheap but it works.
Couple wiring-related things under the dash to take care of next which will require dropping the column and taking out the instrument panel. I'm not looking forward to that job but it's got to be done, I want this car to be 100%. BTW, I looked at the
Dakota Digital standard dash set again and was shocked at how much it went up since last year. I could be wrong but when I first saw them they were nowhere near that much, I had it in my head they were around $1,100 or so. Too much now.
Last - the current EFI tune basically had to be re-set so it wouldn't continue to use the learn tables that were compensating for the rich condition. It will take a while to fill the table in again but I don't really have to fix anything per-se, just have to drive it and let it re-learn. Looking forward to getting back to driving this car regularly when the weather gets warmer. Hopefully all this stuff I did stays good for the foreseeable future.
More to come.
