68 roadrunner fender antenna hole
There’s an old antenna base there presently with the cable attached the radio. I didn’t want to take anything apart until I had the new antenna.
Once there is a hole you will have to grind or file the hole to fit if or as needed. So knowing the size at this point is pretty much mute. Once you remove what you have you will know more.
If the base is there and cable still attached to the radio, why don't you just get another antenna mast that screws into the base?
Does the antenna not work? Do just want to change to a different antenna? If you remove the antenna nut at the base and measure the chrome piece. I just measured one for you and the part of the base that goes into the fender is 1.274" so the hole is slightly larger.
When the car was delivered a couple months ago, I took it to a car wash and they broke the antenna mast off. There’s only about a half inch knub left. How could the hole be larger than the base you measured, wouldn’t the base then fall into the hole???
Here’s a picture
