69 Bee 383 oil pressure sender question
MikeyM
1:27 PM
NorCal
Hey all,
Happy Friday. As my 383 warms up and reaches close to the 1st tick on the pressure gauge, it's around 20+ PSI at idle. But when fully warm at idle reads 10 psi with the Rallye dash cluster. I feel that's kind of low but have read that 10-20 is fine. my sending unit is a 90 psi Standard Ignition unit but I think I read that the sender should be an 80 psi unit. I guess my question is - should I get a different sender? One that is spec'd at 80 PSI instead of 90? Is my concern a big deal?
Thanks much,
Mikey
A mechanical gauge will leave little doubt.
See if you can rig one up and run both for comparison. (note readings on each)
Otherwise you will always be guessing.
True. Thanks Don. I have a mechanical gauge on order so we'll see what happens when it gets here.
