69 Charger 440 radiator into 69 small block Coronet?
Aussie Coronet
2:20 AM
Australia
Will it mount up into my 318 powered Coro using the existing holes in the radiator support panel?
Will the trans cooler lines be in a similar position so that I won't have to bend/modify the existing ones?
I understand the hose in/out lets will be in different spots but I can just use flex hose for that.
Thanks mates!
Depends. If your car originally came with a 22" radiator and the one you want to install is a 26", then sorta. The driver's side of the radiator mount is the same, but the hole will be to small to the passenger's side.
make sense?
Yeah, I think so. So the mounting holes are the same, just further apart for the bigger radiator hence only being able to use one side. If I wanted to centralise the radiator I wouldn't be able to use any of the holes would I, as the radiator would overlap the existing ones at each end. Maybe I can dodgy up a bracket but that will still leave a 22" hole for a 26" radiator.
hmm, what to do..
If your thinking of centralising the radiator Aussie, take into account where the shroud may end up in relation to the fan.
