CHAZ666
I just installed a new HIGH/LOW switch on the floor. When I click it all four lamps are lite up, which tells me the HIGH part works. When I click low beam only the drivers side light is lite and not the passenger side. So do I suspect it's a bad ground ? or something wrong with the 12V+ ? I haven't gotten around to getting my multi meter to check, just wanted to throw this out there ? Should I check the harness at the battery that goes to the light assemble ? Or the bulk harnesses at the firewall ? If anyone knows anything that could help me out, I would glady appreciate the help, thanks.
