69 Charger Turn Signal Switch Harness
Macdon221
5:58 AM
Winnipeg, MB
Good Day All,
I need a replacement turn signal switch for a 69 Charger. Tried to just replace the Cam with a Shemar one, but it still just does not work correctly. So going to replace the entire harness.
Which of these three do you all recommend...
1. From Daniel Stern Lighting
Daniel Stern Lighting Consultancy and Supply
2. This one which I am told will work perfectly...
DODGE CHRYSLER PLYMOUTH 1963-1966 TURN SIGNAL SWITCH: TS102
3. Or this one from RT Specialties
R/T Specialties - Mopar Fasteners, Clips & Hardware
4. Another recommendation?
Thanks in Advance.
Macdon221
Most likely all come from the same source. Pick your poison.
I just installed the she-mar from rockauto in my 69 Charger. It initially did not return to center completely and would keep flashing going straight. It seems to be loosening up.
People say NOS is the way to go and I believe them. I just have other places to spend the money right now.
Do NOS if you can. If not be prepared to be disappointed or spend time puttering to make the repop 100%
