Fury1969WI
Helping a friend with their 69 Coronet and have run into a conundrum.
After doing some research, I believe he has the correct style original bar for the 69 down B bodies which came with sway bar mounting tabs, i thinks some have called it the "wide" bar. It measures 45" end link to end link.
However, he has some sort of tubular lower control arms with sway bar mounting tabs inside of the strut rod. He didn't recall if they were QA1 lowers or what brand they were. I did a little digging around on the QA1 website but seems they are pushing their K-member / Coilover swaps more nowadays. There were no obvious identifying marks on the lower control arms but being on the car and well used it was difficult to tell. The suspension was updated about 10 yrs ago. Anyway, i believe they are QA1 or look-alike knock-offs so same difference for sway bar application (maybe).
The sway bar end links measure about (EDITED) 38.5" and tabs are located INSIDE of the strut rod
So, assuming those are QA1 lowers (SKU 52308 - https://qa1.net/products/torsion-ba...wcB&gbraid=0AAAAADpNVTU1O7ZGCvteaFdEhYMNKKdzh).
On a 69 B body with a 69 K Member what options do i have for a sway bar? I find the QA1 website is confusing on whether a 70-72 sway bar will work, their text (can see at above link);
"... Will work on 1966-69 B-body with QA1 K-member and sway bar, and 1962-72 B-body without sway bar."
I understand the 70-up sway bars ran differently, "inside" the K member.
This is a low-buck build, always has been so i'm hoping to find a low buck solution. It doesn't look like there's room on those lowers to weld end link tabs outside of the strut rod but maybe you can hang it from the lower shock bolt??
Looking for ideas and if i'm overlooking something simple. I can email QA1 next week if that's what i need to do. Or contact Pete at BAC.
Thanks for looking/reading this far!
