View attachment 412743 View attachment 412742 R/T already has one. Does the replacement modern technology reduce weight and provide noticable improved handling? It is hollow and less flex as advertised. Also, when pushed hard, the left rear tire just barely kisses the inner leaf. Drives and handles well now, just looking for more. Will 1/4 inch spacers do the job. Wheelwell seems to have lots of clearance outside.
Anytime a few ounces can be shed it is good. She weighs 4050 with me inside @ 200. Looking more for handling.Just how much weight do you think its going to save ?!?!?
.If you don't mind me asking, did the rear tire kiss the leaf before you installed the front sway bar? Sounds as if your back spacing out back is too much or the rear of the car is swaying more because the front can't. Perhaps a rear bar is required as well or just use the spacers.
No, sorry not clear. That's the previous scrub. Put some paint on to help recognize change. Need to go romp. When checking the current clearance, was surprised to find just how much flex there is on sidewalls.So it still rubbed?
