WTB 70-71 hemi 440+6 oil pan
k-ams
7:07 AM
wisconsin
looking for a hemi or 440+6 oil pan. Some dents are fine or if it needs work or surface rust okay also.
thanks
Here is the part number for the pan you are looking for. Hope this helps your search. 2951564
One little tip I might throw out if you end up using aftermarket parts..... when I was putting a hemi/6-pack pan & pickup on my motor for street use I found that the aftermarket pans/pickups are not exactly stock size. What I mean is that I found that I could NOT mix & match the pickup and the oil pan since there were slight differences brand-to-brand (basically, none of them are exact copies of an original hemi/6-pack part from what I can tell). The moral of the story is that if you go aftermarket, get the pan & pickup tube from the same manufacturer.
