70 bee - sitting low torsion bars maxed out
Did you make sure the lower control arm was clocked enough when you slid the torsion bar into it? If its too relaxed or close to normal ride angle when you insert the bar, it will never have enough adjustment to tighten up when the adjuster bolt is sent in.
I'm going to need some photos
I’ll shoot some pics when i pick it up…
LCA bushing shot? Happened to me last year.
sounds like the LSA wasn't clocked all the way out... and/or the bars are swapped left to right.
Something is either broken or installed wrong. My racecar with a 275 lb mega block has plenty of front height using the original 6 cylinder bars.
I think if the bars were one flat off in the hex (LCA not down far enough) you would never get it off the rubber bumper with all the adjustment. Bars have probably been switched from side to side and just fatigued out. Or maybe LCA bushing shot as suggested above.
Also look at the sleeve in the K-frame. Welds might be toast etc. And of course possibly new bars are in your future. Nothing mechanical lasts forever.
