Coelacanth
- 4:49 PM
- May 10, 2024
- Edmonton, Alberta, Canada
I'm looking for guidance on how far to tap in some new oil seals. I have new rotors, Timken races & bearings pressed in all the way, but I'm not sure how far in to tap the new seals. I found with an old seal that it could be tapped in much deeper than in these pics, even so deep that the inner raised part was below the machined hole of the rotor. That didn't seem right because then, the seals wouldn't be touching the spindles when the rotors are reinstalled. I tapped these ones in so that the outer rings are about 1/8" below the machined hole in the rotor, but as you can see, they can be tapped in quite a bit more until they're touching the bearings.
I searched for an answer to this and found lots of threads about which way to orient the seals, but none about how deep to press them in.
