71 Charger oil pan clearance issue
66HOTROD
9:35 AM
Sturgeon Bay. WI
I put a 440 into a 318 k member in a 71 Charger. It bolted right in but the oil pan slightly rubs the steering crossmember. It is a stock oil pan. What do I do to fix this? Thanks for your help. I should add the 440 is from a camper.
I have a 971 that is correct for 73-74 Chargers. Also have 187 and 933 which are correct for C Bodies but work on a lot of B bodies.
