72 Charger 318 fuel return line and/or fuel vapor line?
JR_Charger
1:34 PM
____
Inline Tube has a 5/16" fuel vapor line and a 1/4" fuel return line listed in their catalog. What is this 1/4" fuel return line? I'm sure I only had a fuel line and a vapor line (which appears to be 5/16"). At first I thought the vapor line might be 1/4 for small blocks and 5/16 for big blocks, but that doesn't appear to be the case.
Here's the 1/4" fuel return line - They use the same illustration for the 5/16" fuel vapor line.
Is it 1/4" for Slant Six and 5/16 for V8's?
Thanks!
Any idea how much HP the 5/16" supply and 5/16" vapor system will support?
My target is 500HP at most in this car. I'm beginning to doubt I'll get that far.
I could switch to 3/8 if it looks like I'm actually going to make real power, but then I've still got the 5/16 vapor line instead of the 1/4 return line.
Does the 1/4 return line go to the gas tank? What about the vapor recovery tank? It sounds like the 440 cars must not have had it.
Rockauto has a Liland Global sending unit (SUDG19) with a 1/2" outlet - what is that about?
My 1971 Superbee 383/432 is 500 HP
Like Mopar marks said it left the factory with 5/16 fuel line and vapor line
When I was having ignition issues above 4500 Rpm’s I wanted to confirm fuel pressure at the Carter AVS at all Rpms on the road
So I mounted or taped a temporary fuel pressure gauge to the outside windshield basically in front of my face - The hose ran to a T on the OUTLET of the fuel pump right before the carb
A new factory type mechanical fuel pump was on the engine - The fuel pump push rod was the factory installed from 1971
About the only thing I did not replace internally
At idle I was at 6.5 psi
It never dropped below 5 psi throughout all my testing
I also have a video
So I knew I wasn’t having fuel pressure issues with a Carter AVS and Edelbrock AVS2 800
Mechanical fuel pump and factory 5/16" fuel line
