Tom Patchett
This project followed me home last summer. Drove straight, no big problems. Caught rubber in second gear. (auto trans with 400 smog motor)
Jezebel started to miss after a left turn. Number 7 plug wire was pulled off the spark plug because the steeering shaft walked it out. Got the plug wires sorted out. Needed to change air jets due to killing all the mosquitos in the shop. Things like that.
2 weeks ago. Was about to drop the K-member and change out the bushings. Noticed an odd line at the front frame. The body putty that was painted frame black was cracking off the left frame rail. Might not be stock. So now have 3 piles of pieces that all need rebuilt. 1- frame needs sectioned and welded. 2- front end wants a rebuild. 3- After the other items, had no faith in the engine
so tore it down. Engine will receive bearings and gaskets.
