727 B/B Cooling lines
avidflyr
1:25 AM
west Coast Florida
My 64 Polara is converted from 318 to B/B 408 with a 727 Torqueflite. The "Right Stuff" tube supplier doesn't list B/B cooling Lines for a 64 B Block and seems clue less as to whether later B Body cooling lines will work. It's not Rocket Science ! ?
HELP
I have a new set for a 68. Can measure for you and compare with your old ones. Cant see a big deal with your app. The longer line is 51in and the shorty is 42in. Says for 66-70 BB B body from classic.
If you stick with stock style steel lines, it may be easier to bend your own.
Why not use your old lines? Are they beat up? Use them as a template and bend some up. I actually like to bend up a new set and run them along the left inner frame rail to keep them out of the headers. It's much cleaner.
I Followed dvw's advise.
Flex line from trans over to frame. 5/16 line is a straight shot to the core support, then 2 bends (each line) to the Rad/cooler. Clean, safe, and cooler to boot!
3 out of 4 techs agreed... thanks every one for the replys. .Avidflyr 64 POLARA
