- 1:57 PM
- Oct 18, 2008
- Kindersley,Saskatchewan, Canada
Stupidity. Kim
A low gear burnout. He has line lock and a 500 horse 440 now. 1-2nd gear is easier along with some bolt in pieces inside.Did he have an explanation for the planetary failure?
An aluminum drum is around $650, not $1500. Heck the parts to build a 900hp plus trans are barely $1500 depending on how fancy the valve body is.The sticker shock of adding an unexpected $1,500+ to a transmission build would have most of us posting something?
Been bleeding Mopar since'70
Automatics should be outlawed. I really feel one is missing alot of the "Muscle car" experience with an auto. And racing? There is a reason Pro stock rule #1. No auto trans! (Ok. I made that part up by rule #1. But still no auto's allowed.)
Did that myself. My one 727 auto. '74 Duster. 451. I redid engine. Ditched the 452 heads (That performed well for their times.) for Brodex B1/BS heads. New rods/pistons. New custom grind Comp cam (Mechanical flat lifters) Compression went from 10.5:1 pump gas to 12.4:1 E-85 fuel. By estimates went from 500+ horse to 600+ horse. 727 has bolt in sprag with Kevlar bands. Rear 8 3/4" Mosier 40 spline axles with spool. And what did I forget? DRIVESHAFT! The car was snorting mad and ready to put down a possible sub 10 sec run. Let the two step button go at amber? And the driveshaft exploded so fast the car didn't move. (Thus exploded before line clocks let go.)
Moral of the story? Im still the weak link!
View attachment 1005895 View attachment 1005896 View attachment 1005897
How do you like running E85?Did that myself. My one 727 auto. '74 Duster. 451. I redid engine. Ditched the 452 heads (That performed well for their times.) for Brodex B1/BS heads. New rods/pistons. New custom grind Comp cam (Mechanical flat lifters) Compression went from 10.5:1 pump gas to 12.4:1 E-85 fuel. By estimates went from 500+ horse to 600+ horse. 727 has bolt in sprag with Kevlar bands. Rear 8 3/4" Mosier 40 spline axles with spool. And what did I forget? DRIVESHAFT! The car was snorting mad and ready to put down a possible sub 10 sec run. Let the two step button go at amber? And the driveshaft exploded so fast the car didn't move. (Thus exploded before line clocks let go.)
