mopar 3 B
But assuming the bands are adjusted correctly and valve body is ok there should be no bands or clucth packs applied in neutral. Both clutch packs would have to be applied to make it move in neutral. Big question why is the converter also locked? At idle should not be turning enough rpm to lock it. My suggestion would be to park it before someone or something gets hurt.A stuck rear clutch could make it move in all forward gears. If the high clutch and KD band operate normally the trans would also have 2nd and 3rd gear.
