Petri.
Hi from sweden, i have one -68 charger 383 that i bought from usa some years ago, tranny had 1000 miles on it when i bought it , it has always had a wining noice and 2 years ago something happened and it has been sitting since then because no time to fix it but now its time.
Reverse works and dont wine, the car wont move forward when shifter is in D position , if you put it down to gear 1 you can drive it but it is very noisy "sounds like a bird" and you can also manually go from first to second gear and it still works but very noisy.
So what do you guys think is the problem.
Some are saying this,the overrunning clutch (sprag) has failed. No way to fix it without removing the trans
/Petri
/Petri
