43tutor
My first real road test in my 72 SSP was this past weekend after 2 1/2 years. The 2-3 shift point seems too high.
470 stroker, 2800 stall converter, 3:55 suregrip, 225 70R14 tire (26.5" diameter). Planning to change to a 15" wheel at some point.
I rebuilt the entire transmission with all new key items. Installed a Trans-Go TF-2 reprogramming kit and followed the Trans-Go instructions to the letter. I was meticulous with all the cleaning and assembly so I do think there is any debris in the valve body but there is always that chance.
I believe the speedometer to be fairly accurate but I have not verified. I did install a new 36 tooth gear in the tranny during the rebuilt to accommodate the tire size and rearend gear change. When driving the car I get a nice smooth firm 1-2 shift around 20 MPH. The 2-3 shift doesn't happen until around 50 MPH. Is this normal for my setup, it seems too high for MPH for 2-3 shift.
I adjusted the kickdown linkage per FSM. I adjusted the shift selector linkage starting in the neutral position. I have verified the kickdown band adjustment from 72 in/lbs. and backing off 2 1/4 turns.
My thinking is the governer side line pressure is low and can't overcome the throttle pressure to make the shift until later when the road speed higher. Is my thinking correct on this?
