727 tailshaft loose
Engine, Trans & Driveline
  1. 4406bbl
    4406bbl Well-Known Member
    388
    388
    Feb 8, 2015
    nebraska
    Local Time:
    8:14 PM
    Maybe a durabond coated bushing rp6189t. I have never tried one. On paper it should be .002 tighter than the brass one I have here. Those are for minimum specs, they do not give a maximum. Thinking of trying that and a hard chrome yoke.
  2. AR67GTX
    AR67GTX Well-Known Member
    1,917
    1021
    Jan 28, 2012
    Arkansas
    Local Time:
    8:14 PM
    Is the tail shaft mounted on the transmission yet?
  3. 4406bbl
    388
    388
    Feb 8, 2015
    nebraska
    Local Time:
    8:14 PM
    I just want to add the ford c-6 uses this same bushing, some ford guys are complaining about the loose fit
    As best as I can find ford wants .005 clearance. At the joint that would be quite a bit.
  4. Babyblue66
    Babyblue66 Well-Known Member
    104
    72
    Feb 25, 2010
    MN
    Local Time:
    8:14 PM
    By the way, I did measure it. It's pulled out one inch from bottomed out. Which is what a driveshaft builder said it's supposed to be. It took me a lot of thinking and effort since, ya know I'm stupid and lazy.
  5. Babyblue66
    104
    72
    Feb 25, 2010
    MN
    Local Time:
    8:14 PM
    .005 seems like a lot. All I know is my 66 coronet yoke is much tighter in the trans and that car is smooth at all speeds.
  6. 4406bbl
    388
    388
    Feb 8, 2015
    nebraska
    Local Time:
    8:14 PM
    1" is correct.
  7. Babyblue66
    104
    72
    Feb 25, 2010
    MN
    Local Time:
    8:14 PM
    I installed the smallest bushing I have, measured with a dail bore gauge, into the tailshaft housing which is off the car. It's a Teflon coated one. It has .011 of clearance with the original yoke. That seems like a lot to me. My initial measurement of 4 thou was actually 14 thou using the Alto bushing. I didn't realize my gauge spun around once. Idk, I'll put it together with the tightest bushing I have and see if there's any change in vibes. I have 2 more 727s. One seems a lot tighter when I stick the yoke in it. I may just take that tail housing off and try it. If nothing changes, I'll have to look elsewhere for this vibration problem. I may also get a nice aluminum drive shaft. They're only 400-500.00. Plug and play made to your measurements. If it still vibrates, I'll do a 6 grand burnout till it explodes and park it for another 9 yrs.
  8. Fran Blacker
    Fran Blacker FBBO Gold Member FBBO Gold Member
    10,385
    10141
    Sep 23, 2016
    Connecticut
    Local Time:
    9:14 PM
    My worn bushing had .014.
  9. AR67GTX
    1,917
    1021
    Jan 28, 2012
    Arkansas
    Local Time:
    8:14 PM
    That’s a lot, especially for a new bushing and yoke. Something is wrong with one or the other or both. Can you post the measured dia of the yoke and inside dia of the bushing?
  10. Fran Blacker
    10,385
    10141
    Sep 23, 2016
    Connecticut
    Local Time:
    9:14 PM
    Clearance with new bushing around .003.
  11. Babyblue66
    104
    72
    Feb 25, 2010
    MN
    Local Time:
    8:14 PM
    Just measured both. Yoke is 1.681 bushing installed is 1.690. Give or take a thou because it's not consistently round.
    There's a nice amount of press fit when installing the bushing.
  12. Fran Blacker
    10,385
    10141
    Sep 23, 2016
    Connecticut
    Local Time:
    9:14 PM
    To much clearance . MO
    • Agree Agree x 1
    • Fran Blacker
      10,385
      10141
      Sep 23, 2016
      Connecticut
      Local Time:
      9:14 PM
      Any chance your getting a ford bushing? Any chance you have a ford yoke? Ya it's off the wall.:screwy:
    • Babyblue66
      104
      72
      Feb 25, 2010
      MN
      Local Time:
      8:14 PM
      Ford bushing is the same. I have 3 different bushings. The yoke is the same size as the new one on my driveshaft and another 727 yoke I have.
    • Babyblue66
      104
      72
      Feb 25, 2010
      MN
      Local Time:
      8:14 PM
      So I have another tranny from a 77 Monaco. I pulled the tailshaft housing and measured the bushing. It's a used one with unknown miles and the bushing was several thou tighter than a new installed bushing in the trans I rebuilt. It also has the big rubber mounted cast iron weight. So I installed that. The vibration from 35 to 45 is definitely reduced and it's very smooth at 70mph up. I know a weird guy that's a very good machinest, he makes all kinds of shit for obsolete old stuff. I'm going to see if he'll make a bushing and hone it to fit my yoke. I can almost guarantee my vibes will be gone if he can do this.
    1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
      By continuing to use this site, you are consenting to our use of cookies.
