RT6PK
OK, what is the trick to stopping an automatic tranny pan from leaking? I started with a new chrome steel TCI pan with the supplied rubber gasket. I cleaned off both surfaces with wax and grease remover. I sprayed 3M adhesive on the pan side of the gasket as recommended by several fellow gear heads. I let the adhesive dry per the directions on the can. I cleaned all of the factory bolts and flat washers real good in solvent. I dried everything real good with a clean rag. I tightened the the bolts in a criss-cross pattern like you are supposed to. BUT THE S.O.B. STILL LEAKS. The bolts keep loosening and need re-tightened. Do I need to add lock washers or something?
