jim ritchie
- 4:48 PM
- Oct 2, 2016
- Cherryville bc canada
Most steel 727 pans leak because of over tightening,if you want to use the same pan,,clean well,,place on level surface and check all around with feeler gage for high or low spots and gently hammer so surface is even .Replace with new rubber or nylon gasket and a spot of lock tight on bolts and gently tighten all bolts ,a little at a time in cross pattern,I use a 1/4 inch drive and only turn with fingers or you can torque to specs but most wrench pullers get a feel for it,,but others think if it leaks,then just KEEP TIGHTENING! good luck,you'll get it
