#41
1-Torque 2- front maximum height of 4.08 inches and a rear maximum height of 4.63
inches,
2-The Edelbrock Performer RPM intake manifold -typically has a height around 5.35 inches.
3- Street Dominator -For Chrysler big blocks, the front height is 4.13 inches and the rear height is 5.25 inches
So looking at dimensions and it looks as if 5.35 is my max with a conventional filter.
Any thoughts on the 3 if you think one is better than another?
You need to match the intake to your engine build cam/heads/compression axle gearing and intended vehicle use. That will be the one that will be "better".
