73 Charger Instrument panel swap
koolking1701
New Member
11:58 PM
NC
I have a 73 charger with the regular dash instrument panel. I have the Rallye instrument panel to put in it. Will this require extensive wiring changes. Just wondering if it's a difficult swap
I'm a wire is just wire guy and just make my own wiring harnesses. If you are careful and label each wire as you remove it from the original cluster, you should be able to mate the wires up to the Rallye cluster. If needed, splice in some additional wire to make them the length you need. A few bucks in wire and connectors sure beats big bucks for a new wiring harness.
I just removed a rallye cluster and labeled the harness.
I used masking tape and a sharpie to label all the connections.
Took about 45 minutes including pulling the cluster after dropping the column.
