SE74
- 12:40 PM
- Mar 21, 2013
- Mitchell, IN (shitsville)
Ok, this looks a little slap stick to me. The window opening continues to go around into a deeper window opening in the c pillar on the inside, (picture below) on the outside, the window is mounted to a fiberglass piece and is molded into the C pillar with bondo. Is this something that was done at the factory by dodge? Cus the drip rail has been ended where it should be like an SE should, I just don't see why they would have put a fiberglass piece in there, instead of it being metal. The bondo on the outside of the (pictures) is starting to chip off aswell.
It's a little perplexing, figured i'd ask you guys and see if this should be like this, or if someone has done something stupid sometime in the cars life.
Zach
Zach
