What size is the radiator? 26 or 28 inch shrouds are harder to come by then 22. But it sounds like you have the larger. If you are still running the original post the number that's on the top tank. It will determine the size.
That could be one of 5 rads depending on options. 22 or 26.
The correct shroud is either 2998327 (22in) or 2998326 (26in)
The radiator is probably wrong or aftermarket.
Also be sure to check the radiator opening size. Lots of guys have put larger radiators into cars without taking into account if they put a 26" radiator into a car with an opening for a 22" they aren't getting as much added cooling as they think because there's little or no air flow going through those extra four inches.
