64SF
I recently had a shop pull the 4 speed out of my 64 Sport Fury to reseal because of leaks (the previous owner of the transmission had told me he'd replaced all the gaskets, o-rings etc. which I question now whether he was being truthful). The shop had previously did work for me on automatics and felt comfortable in their abilities.
I picked up the car (after they had difficulty in adjusting the shifting linkage), did the required adjustments and have noticed a few things that I don't recall having noticed prior to the removal, reseal and replace.
There now seems to be a whine in 1st and second gear, in downshifting from 4th to third and from second to first I'm getting a little "grind".
On the invoice they noted they refilled the case with 85W-90 (not sure if was GL4 or 5). I drained that and installed GL4-140. It seemed to quiet the whine down a little but it's still noticeable (maybe it was always there). Still get a little grind in the downshifts unless I go to neutral and double clutch.
I'm in Florida and it's alway hot....that's the primary reason I used the 140 and as I recall when I first put the transmission in that's what I used to top it off.
I've read about different gear oils and different manufactures, using ATF and etc. Any comments or suggestions would be greatly appreciated particularly regarding the whine.
Thanks
Thanks
