I have a problem with the timming setting on the A12 motor.I read the manual book say 5 or 10 deg advance and the rotor on no1 to the distributor cap and I set up and try to start the A12 with a problem it stop running and hard to start can some help on the right set up with the timming as I hope the cam and crankshaft timming is not out as this A12 motor was rebuilt.When the A12 is running and the timming light is on is shows more than 20deg advance and when you turn the distributor retarded the timming is just under 20 deg advance and not 7deg advance by the book.
