A518/A500 overdrive into 62 B body ?
rustytoolss
4:32 PM
New Franklin, Ohio
I have an A500 overdrive transmission. At some point I would like to install it into my 62 Fury. I know I will need to use a different shifter., and have a drive shaft made. But my question is, How well does it fit ? And if you need to do work on the floor pan, and how much. Any pictures would help.
Holly has Transmission support adapters and some decent you tube videos. Apparently you cand pound the pan and trim some tabs from the trans. Check it out.
