Mopewbie
- 10:01 PM
- Sep 10, 2021
- Ash Vale, Surrey, UK
A ones are NGK B6S (being replaced for AC Delco R43S)Send us the plug numbers and approximate milage on each.
Mike
B are Champion RN14YC (being replaced for Champion 3405)
No idea about mileage, got the car with them and just checking it now.
Personally, i would use AC/DELCO R44S as its one step hotter.....or consider Champion RJ-12YC or Autolite AP85. The origional NGKs shown as just a little too cold. Origional plugs were Mopar P34P equal to Champion J11Y. The current venue of plugs have a copper component in their center electrode which results in a broader heat range. But mixture, spark advance characteristics, cam shaft and compression ratio all influence the spark plug coloration. Just my opinion of course.
BOB RENTON
Thanks all for the answers. It's very satisfying to be able to ask anything from silly to highly technical in this forum and always learn somehing.Don't know why you had the the B6S plugs in the 440, not even recommended for a stock 6bbl or any 440. The stock plug would be a GR4 or a BPR4ES. Without any info on compression, cam, ignition, exhaust, it's hard to say what would work, I use NGK R5670-6 with my setup with very good results.
As far as the 318 plugs go, was it a factory 4bbl, or was it added, and what year is the basic engine? Need more info on that one.
I would also use NGK plugs before AC's, but that's just been my experience, and everybody has their favorites, just like politics.
Mark
1973 318 used a Champion RN14YC or NGK GR4. The 340 used the same plug, so it seems the 4bbl doesn't change anything.
Something of note though, the Parts Watch program we use is incorrect for a 1970 V code 440 and gives the small block plug as the factory plug. The actual plug would be a Champion RJ12YC or NGK XR5.
Sorry about the bad intel, but in my defense it was a mistake in the parts program, I'm just happy I found it before I got crucified for giving bad info.
Mark
