So...it looks like I'll be good to go getting a unit without the spacer. That should put the base about a half inch above the KD stuff. I see that Allstar has 16" elements, but didn't see a 16" assembly.
Yep. Without the 1/2” spacer, that makes sense.So...it looks like I'll be good to go getting a unit without the spacer. That should put the base about a half inch above the KD stuff. I see that Allstar has 16" elements, but didn't see a 16" assembly.
That does not look like the factory throttle linkage location, which doesnt matter with a manual transmission, but will not work with the factory KD linkage.Here’s the clearance I have with mine using the 1/2” spacer.
Yea, it isn’t, the car didn’t come with much of the original setup. I was going to source it all but the transmission had a manual valve body so I just made my own bracket.That does not look like the factory throttle linkage location, which doesnt matter with a manual transmission, but will not work with the factory KD linkage.
I think you need one of these to put the linkage in the correct location, which will change the location and clearance.
