LemonWedge
I got the new alternator swing bracket fabbed up, and got it installed. Seemed like it fit pretty well; a little close to the head at the backside, but not bad all in all. Wired it up with a new voltage regulator and everything seemed to work..... too well. I was seeing as much as 17 volts when it came off idle. Wiring seemed correct, so I called my wiring guru. He had me feed the Reg straight from batt +. As soon as I did that, voltage leveled at a rock solid 14.4. So I wired in a relay to feed B+ to the reg when the key switched on. This seems to be working just fine.
All of this wiring fire drill was Sat AM.... I then loaded up and had the first points race of the season Sat. Afternoon. It was a thrash and I’ll probably go back and redo my rushed wiring.... but the car was rock solid Sat. Night! I ran the cooling system after each run and never put a charger on it.... it was just fine all nite.
I made 7 passes Sat night, all between 11.278 & 11.295. Went 5 rounds, bowing out in the Semis to one of my best buddies who posted a .017 package to put me into the beer cooler.
Great day for sure! The season has started, and Lemonwedge made the call in just the nick of time.
