rumblefish360
Thanks. To further explain it, it is a lad to create a quench area. Would that work as well? I figured the work “Dome” would be OK enough to get the idea across. As a basic ....
Yes but different from. most domed pistons... The dome typically is intended to fit into the wedge shaped area around the valves.... A quench pad is designed to fill the open chamber area opposite the wedge shaped area around the valves....
Since the Edelbrock heads are closed chambered a quench pad piston would collide with the head...
