anybody know???vin code question.
Bear R.-
3:51 AM
snowflake arizona
hi everone.barry here.just wanderin what this "K"means on my 67 coronet.its punched out .never seen nothing like it.is it rare? should i be running from that sh&^%..ha..ha..just kiddin..can somone help me w/this????thank you and God Bless!.Bear R.-
not sure if that is rare or not,i have seen that punched out on a couple of my cars also.It might just be that whoever stamped the tag did it for inspection purposes,like when you buy something and there is a tag on that says inspected by whatshisname.I'm sure somebody else can chime in that might give you a clearer reply.
It's a typical inspection stamp for the St.Louis plant. They used different stamps but that's very common.
What is NOT common is a /6 three on the tree car. :)
yup, inspectors punch. Detmatt covered that in a previous post. It's very common and all it did, back in the day, was verify that someone had checked the build sheet against the sales order against the VIN against the actual car setting in front of them.
build sheet.. for,pops1967GTX.....
hi pops.this is the only way i could send it to you for now..thanks and God Bless Bear R.-
My 69 Bee has a "T" punched on the tag....
other half build sheet
hi pops,heres the other half of the build sheet.and 1 full veiw of it.thanks and God Bless..Bear R.-
Bear vin decoded.....
VIN #WH23B77219390
W = MAKE=Dodge Coronet / Charger
H=Price Class =High
23 =Body Type= 2 Door Hardtop
B=Drive Train=225 145HP 1-1BBL 6 CYL
7 =model year 1967
7=Assembly Plant = St. Louis, MO, USA
219390 Sequence Number= 119389th Vehicle made at the plant....
good web site for information....http://www.mymopar.com/decoder.htm
Bear, did you find this sheet in your car? Have you noticed it's not the BS for your car?
