gkent
so the quench is about 010.
Slap in a .039 Felpro and you're good to go. Or is that too expensive for you ??
I think he’s saying he’s .010 out of the hole? If not then I’m not sure what the problem is. I was thinking he needed .050 minimum but who knows?Slap in a .039 Felpro and you're good to go. Or is that too expensive for you ??
He is trying to use an open chamber piston (quench dome) with a closed chamber rpm eddy head, and he probably has piston to head contact with a standard head gasket.I think he’s saying he’s .010 out of the hole? If not then I’m not sure what the problem is. I was thinking he needed .050 minimum but who knows?
No, but crashing the pistons into the heads would be.Slap in a .039 Felpro and you're good to go. Or is that too expensive for you ??
Might have intake sealing problem.
I'd just have the pistons shaved 040" or so. Too likely for trouble with gasket stacking.
The crank bobweight is balanced by 1/2 the piston weight, the quenchpad isn't that much area, if you do limited grinding we are talking only a few grams...something you won't notice.
Use a .051 head gasket and take .020 off the quench dome. Or take .030 off and use the felpro .039. If you need less compression then cometics. Take the pad all off and I don't know that you will have any quench at all... it depends what piston your using?. I would figure out a goal for compression and choose the best gasket and machine the piston for quench accordingly.
I bet your figures are right on...I was going on what he stated as .010 clearance.. I was figuring its .030 proud.The OP has not been very clear on exactly what he's got. Generally, both of the KB quench/step head pistons are about 0.040 to 0.050" proud of a typical deck. If that is the case, probably 8 to 10 grams.
